085 Gearbox code identification
From on-line VW workshop manuals
GEARBOX CODE LOCATION
  • Replies 22
  • Views 15.8k
  • [3.1] 084-085 gearbox.ods Hi here, So I've produced ▲ this ▲ file that regroups all known 085 gearboxes and information about them.  Only rule is please do not modify it and then advertise it
  • Ah yes, if you keep clicking next page on my top link then you get to the same thing you have PDF's of :-D Here is the layout of the gear sets Transmission layout inside the 085
Here's the list of the different codes with the ratios etc.
Thanks Nige. Those look like info on the 6N > onwards boxes. Do you have the same for 86C 085 boxes?
Those are from Elsawin and it only starts from 1995 for the 6N :-(
Can't download the pdf :(
Which one?
Both
Both
Just tried both and no problem?
Somebody must not like me.....
  • 6 months later...
These links aren't working for me now.
I used to have them downloaded but i had to do a factory reset.
  • 10 months later...
Sorry, you don't have permission for that!
I can't download 085 Gearbox codes 2.pdf
  • 8 months later...
^ sorry to be a pain... I can't load the pdfs, no permission?
Anyone got any data on the 5 speed box fitted to the later formel e? I can only see the 4 speed on that German site.
It won't show up on Elsawin as it only covers from 1994/5 onwards :(
Boooooo!
I'm sure there used to be another guide somewhere that had them all in but I can't find it now
anyone knows the gear ratios of CEE?
I know it comes with the 1.05cc engine AAU, but I can't find any ratios for this box... only for AYZ and AHZ for that same engine
Edited by Fifress
If you go to www.vagcat.com you need to register but that's free, then you can get the individual gears #'s of teeth and then work out the ratios, unfortunately it's a pre 95 box so the details are'nt given in elsawin :(
  • 3 years later...
https://polomagazin.de/index.php?article/38-pologetriebe/
has Polo ratios in a nice web page.
This row...
GKB
(gearbox code)
MKB Engine Type Style 1 2 3 4 5 Reverse Final drive
CEE AAU 86c 5-speed 085 3.455 1.958 1.250 0.891 0.740 3.384 4.267
Edited by dvderlm
  • 1 year later...
Hi here,
Only rule is please do not modify it and then advertise it as your own... that's all
Hoping it will be of use to you guys 🙂
Edited by Banora
