Quick question about sub amp compatibility
Hi guys, just bought 2 Apline type-r 12 inch subs. Will they work with a alpine mrp m650?
thanks :D
edit: the subs are 4+4 ohms
Edited by anilc
  • Views 928
Are the subs dual 4 or single
Dual 4 ohm
So they will go on at 4ohms to my amp which is fine
I've bought another alpine amp with exactly the same spec, can I connect one to each sub?
Yes that would be better wire each sub into 2ohms just make sure both settings are the same for both try to keep the wiring the same length on both
Also have a a 1000W Jet Sound JS5075 AMP
Any good?
On another note, does anyone have dimensions for a 9n boot build?
