Project rusty fox
picked up this little project for the sum of £150 2 weeks ago, its a bit of a shed and for £150 saving it from the scrap is worth while, was taxed and tested.... for 3 more whole days, so went and picked it up and drove it 100 miles home and it never missed a beat which was lot more that I was expecting
got some plans for here :-D :-D
some rust areas :?
previous rust repaired by newspaper and filler on passenger wing and drivers one is not much better :x :-X
both front wings will be getting replaced as will both sills which is all ordered and due to arrive on Tuesday
sorry for the bad pictures,
started by removing the interior which was a complete mess so went straight in the bin to be replaced with a new one in the future, :-)
had to wait for Mr post man to bring me a 25mm socket to remove the steering wheel so I could get the dash out
front wings off
good thing is that so far the underside of the car and the battery tray of the car are completely solid except a hole in each foot well that are ready to be welded when the mig welder arrives
passenger side
driver side has already had a patch before nut just welded straight over the rust so all rust cut out ready for new patch
5b4e5abb-20f7-4d84-b932-3c62e730cad8_zps
practice welds with a borrowed arc welder......
actually made myself laugh.... ill just wait until I get a mig welder :lol: :lol: :lol:
  • Replies 41
  • Views 4.8k
  • finally today the shell went into paint really really happy with the results the pictures really don't do it any justice finished result time to start putting it all ba
I recently got a mig and my first welds just blew through the metal after getting the setting right a few hours practise my weld are no strong and don't look to bad. Just practise before you weld the car. Some good progress any plans?
Yeah arc is a bit extreme for something like a wing lol
The wing was beyond repair so i was just using it for practice on but yes practice is needed considering the amount that needs to be done, plan is to get the bodywork looking like it has just left the factory then hopefully stick a carbed 1.4 16v in and a few bits and bobs along the way but any mods will be subtle
Exactly what I've done engine wise and the same colour coupe too check my poor build thread if you wish
I will do going to need as much advice and guidance as possible with this being my first proper project
little update, got these delivered today
both sills and passenger front wing, welder and driver side wing due to arrive tomorrow and the work will start Thursday at 11:15 after my final A level exam :-D :-D
will update again then
  • 9 months later...
not updated for a while but its getting there hopefully be ready for all types on the 18th of may but being in uni and trying to do this at the same time is a bit of a struggle but some progress
sorted the holes in the footwells
put some fiberglass on the top and underneath the patches that i put in then underseal on the underside
fixed the rust on the rear valance
stared off dealing with rust on the doors
both doors had the same treatment
doors and wings prepped for paint
then painted :D:D
not an original colour something a little more modern but very similar
after all this I started on the sills measured the new ones up cut the old ones out then welded up the new ones on pretty pleased with the result
grinded down the welds and filled up the joins and at this time tackled the rear rusty arch on the passenger side
sorted out the surface rust on the front
(still needs flattening down for paint)
took the engine out ready for this going to run it with standard injection and immobiliser and still to clean up and give it a full major service whilst it is out the car
plenty of wiring to keep me busy
80-60 lowering kit to go on after paint
the shell should be going to paint within the next week or so it is ready just waiting for the flat bed to take it to the body shop :D:D
boot and bonnet also pained
dont have a pic of the final result will get one up this weekend
pressed plates to go on when finished
Edited by T4R3KP0L0
Really good job cleaning the shell up.
liking this, considering getting a mk3 project like this
Thanks guys, definitely do it man this is my first and learned so much already doing this one
870DACD6-9C69-4E9F-9CCF-41F3CEFA26E1_zps
D3AEC876-E65D-44B1-B417-9C407F62ACF5_zps
4C58BF59-3BD5-4CB6-A4EB-301E12BE5FF5_zps
38F8E03B-37B8-4BF6-9213-F5D1A81E76FB_zps
3E1C4123-A2A3-4DFB-95B8-518343D4A755_zps
finished result
07556F0B-037C-4442-8E7F-43255C780DA4_zps
25A59CF2-51CF-4E40-A87B-5FEDC77549B1_zps
3B561110-FC59-4D85-AB9E-590072C17A57_zps
1754084F-4DD7-49EC-B7C0-F90FBA28AC60_zps
097C92AB-86FB-40BB-9ACE-325D44F59A57_zps
BE5E5628-4781-4B9F-8DCC-3EF854364010_zps
B056C226-CBF3-4CEB-A673-AEF8431329F9_zps
2EECD399-C2CB-4748-BF7B-D40938F511A2_zps
9E627C12-474D-4E6F-8734-CA053290DC60_zps
time to start putting it all back together now at last
let me know what yous think :D
That looks sharp great work am really looking forward on the next steps :D what paint did you use ?
Thanks alot of effort has been put in, the paint isn't original is power red not exactly sure on the paint code, just putting it all back together now really and a few extra bits
Keep up the good work boss :smile:
Awesome , I see you kept the fire wall though , crazy colour
thanks. the pics dont really show the colour or do it any justice.
made a head lining out of suede fabric and fitted it today
roughly held it in position with paper clips then used resin to bond it.
EF672E03-CF5E-4C99-A2B1-EECDFB5FB8A6_zps
E262441A-A5FF-4AF5-845B-FEE7D525D959_zps
really happy with the finished result
7D8DB0F5-FDFB-4E6D-862A-A55CD9D66490_zps
stuck the windows in and put it back together ready to start tinkering with the underside and the engine next
FA899124-E4E7-4963-8133-10FEA712F46A_zps
AEFF6DB3-175C-44FE-AF84-DA118563423C_zps
3A16A83C-B0CE-42C4-A303-3A398FF5CE4E_zps
85BED677-E64E-46F5-B764-A86FA92EC036_zps
more updates to come shortly
love this dude, keep it up. nice to see someone rebuilding it and not scrapping it just because of some rust
thanks mate, been a dream to work on to be fair
small update
after work took the front struts off stripped then sanded down then a quick coat of hammerite driveshafts are still on though dont have a 30mm socket yet,
524B5015-6DCD-4BF1-B03E-A8EFDDEA5C28_zps
made one of these using a spare socket
736CB36D-F1B0-4AD2-ADF5-C13A0D51C5BF_zps
all painted up
57656772-92F5-4170-88E5-F6C9D155199B_zps
the old shocks were past it!!
4DDCB987-B8AA-40F4-8C3B-5B0FDC80A995_zps
work was quite today so decided to start polishing up the wheels i got
DEE315C1-FDA7-4192-BB3D-C568DF97E58E_zps
F6C9E885-DB19-4C5B-8615-CE6CD39F8F96_zps
646BBA5D-A2C1-45CE-A55E-BB83287145D3_zps
10821551-77E5-4105-949D-016B07C09735_zps
E923CD06-189F-4D7A-9CB1-2AB9FFAAEA48_zps
5BCD738E-E17F-4944-AA54-30C94CA51D7F_zps
DBFDEF95-E5EB-4B14-A9CF-DB2AC774201E_zps
one wheel nearly done still not exactly as i want them so going to give it another going over tomorrow
Edited by T4R3KP0L0
more pics of the wheels
8D1590C2-371B-41EC-8F34-9242DAFAC28F_zps
i think a 60 drop suits the car a lot
570CE7F7-512A-4BF7-B321-2A339EFBD33F_zps
might need to get a spacer on the back to get the wheel out the arch
9AE90E11-12C8-4204-8371-B0F930DC15B2_zps
F954D9A8-7CB9-473A-9DB4-B6C29086860B_zps
also got the bumpers and lights back in, playing the waiting game with the engine atm
1C6B91F8-7281-4F72-94EC-77DAC3B35B87_zps
G-ladder arb blocks and poly-bushes are on rout from Germany... more updates to come
Edited by T4R3KP0L0
This is awesome! If i had the money and knowledge, would definitely do something like this! Keep up the good work! :D
haha thanks really dont have much knowledge or any money but hey thats what student loans are for right?
Ahah, Yeah right! What wheels have you got? Looking very slick! :D
Bloody impressive mate. Paint works lovely
thanks, the wheels are RH arrows which are very rare that i picked up from JregGT for a bargain price. they had been sand blasted so now i have the pain staking task of polishing them to a mirror shine and getting the inserts and insides sprayed gloss black.
hoping to get the engine in before the 5th of june when i take a 3 month road trip to tunisia in an ice cream van (thats another story though)
