Shortened Gear Sticks?
Done a quick forum search on this and couldnt find anything,
Is this something that people on here have done?
I saw a car in this months PVW and the gear knob just looked so much closer/lower down which i think looks tidier.
I'm guessing its just a case of chop and paste as it were, but wondered if anyone else had done it.
Pics?
Here is a pic of mine i just took, its as standard, so you can kinda see what i mean. It just looks really long i think.
Edited by polocollector
  • Replies 22
  • Views 1.8k
Jamie's just done this with his mk2f, pretty sure he just cut the gearstick down and screwed the gear knob on?
Thats what i was thinking, but then surely youll be cutting off the threaded part?
I dont want to make a bodge job of it!
Just use a suitable die to cut a new thread
This is a right old mod used to do this years ago before "short shifts" were about
I want to do this on my n2, but I can see, at the top of the stick there is a slightly pressed in flat side, I'm unsure if this is going to create issues if chopped off.
Yeah oldskool, My bro and all his mates used to do it.
I'm not using a standard knob so i just cut it .. Drilled into the knob a smaller hole and grub screwed it on !
Hi did it to my 6n2 a while ago and kept my original gear knob il give you a quick how to first pop up the base of the gator and pull up over the knob then your see the metal retainer for the knob open this up with a flat head screw driver and pull the knob off now remove the gator from the knob,now your going to need some mole grips and a hack saw. Now with your knob and gator separated cut the base of the knob off (blue bit and retainer clip) once that's cut off put the screwdriver inside the knob and measure the length of inside of the knob, now look at the gear shaft and your see the plate that the spring sits against now knowing the length of the hole inside the knob clamp the mole grips at that hight from the plate of the shaft so you know where to cut it to and having them clamped on will help stopping you from slipping when cutting the shaft, now with the top cut down tryle fit your knob and see how it fits now you need some glue and a cable tie, put the gator back on and measure where it now needs to fit on the lower knob and turn it inside out and cable tie it to the base of the knob and now put some glue inside the hole in the knob and push it down onto the shaft clip the base of the gator back in and job done 15 min job
If I'm giving a Polo a bit of backroads abuse, I just tend to grip the stick at the bottom between my 2nd and 3rd fingers. Takes a little practice, but it's no different to a quick shift in principle.
Yeah i used to do that yeti, But now i've got new seats what are on the ground i felt having a shorter gearstick was a must lol
This just seems so wrong to me! Gearsticks should be no more than a handspan away from the steering wheel!
This is what you want!
dunno how well you can tell from this pic, but mine is shortened by a couple inches... gear knob is glued on with araldite and has been fine for nearly a year now :)
Not for me, really don't fancy sequential at all.
But like Toby said, higher or nearer the wheel. I'll make a longer one when I get around to it, though i'll make it short travel.
With the rubber boot replaced by a leather type gatier that barely breaches the carpet, it already looks like a walking stick compared to that 6n2 one though..
As my seats are alot lower it makes sence too as felt like i was throwing barge pole around lol
its not sequential. its just a Cae alloy short shifter for cable gearboxes
Yeah, well, thanks to work I could make one of those for about a tenner.
Though it'd probably take about three weeks..
id love one!
Off topic a slight tad, but Eric, what are those "Polo" trims on your skirts from? I can' think for the life of me, I swear its the Zender kit :s
think they just come on early model coupe s' mate
Yeah mine had them, had to peel them off for the respray and they stretched and snapped so I couldn't reuse them.
So I'm looking at '85 and below, sweet, cheers guys :)
I didnt think they were standard on a coupe s as my brothers old one didnt have them. Bare in mind his was an '87
I've also briefly owned a c reg coupe s which was just before the crossover so between late '85 and early '86 and that had them, but that also had them, but my '90 coupe didnt.
