6n2 arch rubbing
just had my arches rolled and flared a little bit but still rubs where the side panel attaches to the bumper, has anyone had this problem too? I'm now running 15x8 axe ex8 wheels and been told to run a little bit of camber on the front?
  • Views 1.7k
Stretch tyres?
A lot of people cut these out but the bumper won't fit so good after though. What tyre size are you running? Would be good if you can get past it with some more stretch. Is it the front or rear or both?
I'm running 195/45 bit of stretch there, mainly the front mate
Do you know how much camber your running if not to much could increase slightly and maybe go for more stretch but that depends on if you want to run mad stretch ie: 165/45
I'm running no camber at the moment, i think thats the only way to stop the rubbing is to get abit of camber
Yeah I would give that a try easy enough to do aswell.
