Chrome door handle problem!
Just bought myself a set of chrome door handles for my 6n, put it on no problem and thought it looked great, only problem, I pull the handle to open the door yet it doesn't, I don't know the word, retract fully, it goes half way and I have to push it back into place. Can't be arsed with that so standard ones back on now.
Just wondering if anyone has the same issue and has a fix? Possibly doesn't retract properly as they're too heavy for the mechanism.
Any help, I would love! Cheers :)
I had them in my old 6n... No issues at all!
Not catching/rubbing slightly on the plastic surround are they?
They catch when they're pulled open, but when released no, easily pushes back into the right place.. might buy some more plastic ones and spray them up purple, definately work then haha :)
Are they 6n2 ones, if so the mechanism is longer on the 6n so you will need pliers to shorten it by bending the wire. Just a thought. If so when you do bend it take the handle completely off or they will snap, for sure
