AEE parts: head, block, Kent cam, manifolds, mk2 ignition etc
Contact: 07415 384304
Price: As stated per item
AEE cylinder head rebuilt by Cylinder Head Developments (Bromsgrove) just a few hundred miles ago. Should fit other 8v 6n engines but check first. Ported and polished, raised compression ratio, Kent GS1 camshaft, vernier adjustable pulley... £250 ONO
1043989_10151527596959024_877593928_n.jp
AEE block, rebuilt around 5,000 miles ago with new genuine VW shells and rings (parts receipts present). Will come as bare block. Sadly one piston is damaged and the bore will need re honing... £150 ONO
1013904_10151531071974024_785100894_n.jp
8v 6n cam cover, polished, good condition but would benefit from a quick dash with Autosol... £60 ONO
1005974_10151531071784024_1402834377_n.j
Mk2 Polo ignition setup. Comprises of ignition coil, ignition module, distributor and as much wiring loom as i can cut out of the car. Vacuum advance now blanked off and distributor recurved. Brand new cap just fitted. Ignition module still under scuttle in picture... £150 ONO
1005717_10151531059519024_1940853403_n.j
AEE timing belt and tensioner kit, about two weeks old, fitted but not covered any miles... £20 ONO
May sell - AEE custom stainless steel inlet manifold for running bike carbs or throttle bodies. May fit other 8v 6n engines. Made by Bogg Bros, cost me a fortune... £100 ONO
Edited by leeds_finest
  • Views 477
Pics of the manifold?
Added the only pic I have at the moment mate.
Heat wrap is a little dirty under the sump etc but the visible part in the engine bay is nice and clean.
Still interested in the cam mate :-)
Ok let me see how I get on this week and if not then you can have the cam separately.
Will take sensible offers on all parts.
There's some good parts for sale here so try me, worst i can say is no.
how much for the cam? what spec? thx
PM'd.
Custom ground to Kent GS1H spec.
