6n2 roof rack strips easy to take off?
Hi not sure what proper name is but are they easy go take off as need to spray them cheers Pete
Also is 5dr ones same as the 3dr
Edited by petew
Hi mate,
As far as I know, they are the same. and they just pull off. might need to get something flat under the front, but after that you will be able to pull
Cheers so will have to glue it back? It are they clipped? Thanks pete
There held down with spring metal clips & 3 & 5 door roofs are the same
Cheers for the help!!!! Glad there clips pete
