BBS Mahle on a 6n
Got a set of 13" bbs mahles, tried to put them on 6n but won't fit over the calipers!
Anyone know what size spacers I need and what length bolts?
  • Views 922
8v or 16v?
Some 6n's got VWI brakes, they shouldn't be a problem.
Many got VWII brakes and you can use washers over the studs just to measure how much clearance to use (obviously i'm not suggesting you run with the washers).
16v models got totally bigger brakes and you ain't getting 13's over them.
It's an 8v mate, and it had a set of 13" alleycats on it which fit with 5mm spacers!
And didnt think about doing it like that, cheers for the advice!!
