mk2f polo parts
Hi, I have recently converted my polo to g40 turbo so everything I have left over is for sale.
1275cc gt block around 80,000 miles good condition no leaks good compression comes with sump, clutch and flywheel - £50
gt standard head out of same car done 80,000 miles recently been rebuilt and has gt cam great upgrade on any 8v engine - £50
gt inlet manifold good for g40 upgrade or just on gt conversion - £25
4x gt injectors no rail - £15
g40 inlet manifold painted blue has had some porting done - £15
2x gt throttle bodies one needs holes from wedge filling in and one is untouched - £15 each
gt air flow meter comes with standard rubber pipe - £10
golf gti airflow meter set up for my car at the time, comes with red samco elbow and restricted top hat and adaptor for a cone filter great mod for a gt - £30 (pipe cost that on its own)
2x gt ecu's one with a ppp chip and one with fahrvernugen chip both 6.8k limit - £15 each
gt engine loom all plugs present and working - £15
gt front strut assemblies both sides with lower arms and standard springs - £25
gt vw1 front brake calipers not painted seals all ok only swapped as got some vw11's for free - £15
gt exhaust manifold and downpipe with cat still in great for bolting on for m.o.t or as a standard replacement - £20
gt radiator fan and shroud fully working both speeds only removed to fit slimline for turbo - £15
k03 turbo no play great condition, decided to go bigger so never got used - £60
probably have more if you ask I can check all items are COLLECTION ONLY FROM WR11 8SA will not post
can do deals for more than 1 part and will consider sensible offers
not on here much so please contact 07792115829 for fast reply.
cheers Joe
  • Views 397
108 miles away :( was interested in the turbo too....
pm'd
Manifold, golf afm and pipe now sold
Also have a turbo kit for sale see build thread for info as breaking whole car if enough interest
Cheers Joe
