Polo 9n3 (rust in door sill + Inside of bonnet)
I've recently noticed a spot of rust has started to form on my passenger side door sill, right on the inner edge though so it's not like it's been stepped on and caused paint to chip, and also on the lip at the front of the bonnet but on the inside it's started to corrode right the way across (by front i mean the side nearest the grill)
Has anyone else had this problem?
I took it to VW who have said they would cover 75% of the repairs but I would have to cover the last 25% they said the reason they won't cover 100% is because it's not through corrosion :S They said it could be caused from external influence (ie, stone chips etc) But it's the inside of the bonnet and righ on the edge of the door sill where you can't get your foot into.
anyone else had luck with getting their vehicle repaired on the 12year anti corrosion warrenty?
it's only a 57 plate as well.
Edited by chee09
  • Views 2k
bump! anyone?
