6n center console
I'm using the factory one but customizing it, moving electric window switches, reshaping gear stick surround, adding a passat arm rest etc. Molding it all together and vinyl wrapping it, just wondered if anyone had any advice when doin this. I've had three 6ns now so I'm bored of the basic layout. Also if i was to change the colour reflective strip on the heater controls, would i need to just make a new piece in whatever colour i require?
Got some carbon fibre wrap to, which I'm going go mad with, does it pretty much cover anything and is it as easy as it looks on YouTube? Sticking down with a heat gun or hair dryer?
  • Views 972
you'll find the smaller bits are the hardest to do, but i would recommend using a heatgun, worked well for me anyway.
