switch fire!
Been having a few probblems with mrs polo in recent days. First off gearbox went boom, had to have it replaced at a cost of £600, then rear disks and pads needed doing, there was nothing inturms of pad on the one side no wonder my rear alloy looked like it was going rusty, with all that metal on metal action going on! After all that the engine is started the act like its about to die, if you look at the engine every now and again it junks and it won't accelerate, bought new plugs and changed the fuel filter seems ok now, might change the coil pack.
Anyway while all this was going on i notist that the passenger window switch was not working, the button (driver side) felt as if it was stuck, sticky like somone had nocked a can of coke over it, so decided to take it off and have a look
  • Views 748
Not ideal, is it. I've got one of those handles you turn in a circular motion, quite good they are. Toddler in the back of the mrs' Golf throws drink all over the rear electric window switch, though being vertically mounted it should be better protected against splashes.
Seems to have done quite a lot of damage to the wiring before the fuse went, the non-flammable materials have done well to hold out. I'd go with a new (used) door loom, if it connects at the door shut like some VW's do. If not then just splice a new section in behind the door card.
Bloody lucky there chap not to have a big car inferno! New switch and loom time.
actually saw a ford today that went up right outside the owners house!! Cars gutted, front door on house and two windows need replacing as well as lots of smoke damage! Shouldve got a pic.
Time to get splicing!
