vw polo 1.0 e 6n2 cooling fan problem
As it only works with pin 2 & 1 linked, that is the slow speed setting on the correct two speed fan, so it should still work when the water temp gets to 92c
  • Replies 32
  • Views 33.5k
right so the problem has to be the fan switch! will try another new one tommorrow fingers crossed
Either the switch or the water is'nt getting to 92c actual temp. That's why I suggested testing it with boiling water
will try that test tommorrow if possible,any ideas why the water isnt reaching temp? if that is the case?
If it's anything like the all alloy engine (AUD) in my Ibiza, it just seems to run cool, the only time I've seen my fans kick in was when I left it running stationary for 30+ mins with the A/C on full
well after having another snoop around i decided i was going to try hot wiring from fan switch connections straight to the fan but i took a pic of the terminals from behind the fan and found that one pin is missing or the fan has been replaced by a previos owner and got the wrong type of fan ? I'm unsure if I've lost fast or slow speed?
I'd be careful mate as you can get both 2 and 3 pin versions, and the colour of the plastic casing around the pins depicts the temperature range in which it activate and deactivates the fan.
E.g. this is the on i got for my bread van
http://www.gsfcarparts.com/931vg0240
cheers mate well it clearly must just run cool,took it for mot yesterday and it passed without any minors so maybe I'm just worrying about nothing maybe?
Dont think its the sort of thing would get picked up on an MOT. if you're doing a lot of continuous driving the fan won't need to run as you drawing a lot of air in through the grill. The only time your fan will kick in is when you are stood still and or doing town traffic driving. Just keep your eye on it bud. If you do notice it to start over heat an old trick is to whack your fan heater on full this can can help cool your engine slightly if the rad fan isnt working.
