Traction Control Arm Ball Joint Instead of a Bush
I'm getting Pete to make me a set, I don't have access to a mill or a press, or have the skills to use them.
Plus you've got to wear shoes to be allowed in a workshop
  • Replies 34
  • Views 3k
Hahah I love you Jim.
I'd try and source a decent rubber booted suspension link rose joint of a suitable size from a production car as apposed to using a spherical bearing too.
Apologies to anyone who takes me the wrong way - I don't word things well but do mean well, hard to interpret it correctly over the interwebssss
Had these on mine for a few years now, do the job nicely :-)
What happened to production of them Yoof? I remember you advertising them on clubG40 a while back, did they ever get made in larger numbers?
do the rose joints even make that much difference?
The rose joints help stop pre loading the inner bushes when lowered or when running arb blocks
Depends which axis you're referring to about preload, as you can always just slacken and retighen the bushes so there's no wind up at your new height.
The rose joints are more compliant in certain ways, and less in others, so the arm will move easier, but you'll probably notice a bit of an increased amount of harshness into the cars ride quality
i think pete means the preload for where the arm will be forced forward when fitting arb blocks because of the offset on the block, i know the offset is there to correct caster angle when you lower but it still pulls the tca forward putting pressure on the inner bush, I've still got my g40 tca's but the outter ball joints are worn so I'm gonna try press new joints in hopfully.
Yeah that's what I mean depends on which axis likee
Infact you don't even need a press ..
12364c16fe21b04d2bc4aa35a9063952_zps0850
6024edcd647007eac1a3bf04ec7ae616_zps7bdd
