How to remove front wing
Hi,
So a bit of an unfortunate day. My car ended up in a ditch the other day as there was a severe accident ahead of me. It was either a ditch or to join the others. Luckily the people/I/car has no major damage besides the wing mirror and front wing.
Can any one confirm how to remove the front wing on a 9n 2005 pre facelift polo? Good condition ones are around £50 on eBay, so just want to explore my options before I commit to anything.
I have found another guide on a mk7 polo - do you think this applies? - http://wiki.answers.com/Q/How_do_you_chang...swagen_Polo_mk7
Just FYI, my passenger door won't open as the wing as bent behind the door.
Edited by mitchy101
  • Views 11.8k
Removal
– Remove front bumper cover see below
– Remove wheel housing liner
– Removing end plate → See below.
Vehicles up to 02.05
– Remove side repeater → Electrical system; Rep. Gr. 94
All vehicles
– Remove bolts -2-.
– The plenum chamber cover must be lifted or partially removed for bolt -3- → Chapter.
– Heat wing in area of A-pillar with hot air blower -V.A.G 1416- and pull off.
Removal of end plate
– Unscrew screw -3- from expanding clips -2-.
– Pull end plate -1- forwards out of wing.
Installation
– Before screwing on wing, fit a zinc underlay AKL 381 035 50 to each bolt position contact area.
– Specified torque for bolt: 6 Nm.
– Further installation is performed in the reverse order of removal.
Bumper cover
Removal and installation of bumper cover > 03.05
– Remove radiator grille
– Pull headlight washer system trim -13- up from bumper cover and unclip, and remove headlight washer system pop-up cylinder → Electrical system; Rep. Gr.92.
– Loosen cover -1- in area of wheel housing liner → Chapter.
– Remove bolts -6-.
– Unclip outer air intake grilles -10-.
– Remove bolts -2- and -12-.
Further dismantling is possible only with the help of a second mechanic.
– With a second mechanic, pull cover -1- parallel out of guides (left and right) -12-.
– Disconnect fitted electrical connections.
– Vehicles with headlight washer system → Electrical system; Rep. Gr.92.
You're a life saver! They're the diagrams I'm looking for.
Thanks for the quick reply.. And that was a quick reply!
Luckily I had a PM with the same question yesterday, so I had the details to hand :-)
