steering wheels
should a mk2 golf steering wheel fit on mk2f polo?
If the steering wheel is from a late mk2 it will fit your column
If its an early mk2 steering wheel you'll need to remove the spline adapter from the steering column as the early ones are small splined.
So yes, any will fit but the spline adapter is a pain in the arse to remove
