Early 90's ronals 14inch.
Had these on my corsa b years ago!
Are in need of a refurb ideally as scratches, flaking etc are setting in! No major curbing or damage though and to be honest, they could go straight on a car as is!
Badges are easilly removed from the centre caps, which are all present! Fit some vw ones and you're away!
Sure they're 4x100, please tell me if different! Tyres are more than likely illegal!
Cheapo refurb and new tyres, these will look cool!
£30 before I scrap them, just need the space. Image is not the actual wheels but they are identical, just slightly worse for wear :)
Collection from alfreton, derbyshire
  • Views 284
total bargain for someone! they will be 4x100, only issue you will have is that the centrebore will need enlarging by a mm and you might need to run some 5mm spacers. but at 30 notes you can hardly complain! glws
