Flatting and polishing engine bay
Hello,
Just painted my bay with cans, As its easier doing it at home then taking car to and from bodyshop and is alot easier to get into smaller spaces.
Rite now its tornado red which is direct gloss so no clear coat is needed.
Its had about 3-4 coats now so I'm moving onto the flatting back and polishing it up.
Now as we know the bay is a shit shape and is going to be a bastard to use a mop on I and the slam pannle !!
My plan was to flat it back with 1500 wet and dry then move onto 2000 and start with cutting compounds.
Is it ok to use the cutting compounds with a hand pad ( soft and hard compound ) or will this be too much effort.
Just after a few tips on how to bring the shine up as the bay is a awkward shape.
Jamie.
  • Views 780
I'd leave it another day or so yet mate to go off a bit better, but how's it looking atm? Surely be best to wet flat it with whichever grade?
Microfiber pads and some compound then polish should work well after wet flitting with 2k?
Yeah . Its looking good, Just abit bumpy due to the way the can sprays ..
I was going to make a start tommmorow night . Might try flatting it back with 2k then hand polishing it with different grade compounds..
Mate once people see you've done something absolutely rare and crazy (fitting motorcycle based carburettors of the 2 wheel nature) they won't even look twice at the paint anyway
I know!!..
Its like wow, You've put a 1.4.... in a polo .. And on carbs.
I should write a book on how to make polo's gay Fast
