1.3 spi
hi does anyone have any tech info on the 1.3 spi bosch unit ie resistance , wiring, working pressure etc
  • Views 569
Pin 2 of the injector is fed with +12v direct (no fuse) from the fuel pump relay and the earth is from the ecu pin35
thanks so what are pins 1 and 4
Inlet air temp sensor
