1992 polo coupe 1.3 5 speed grey 73000 miles
1992 J reg VW Polo Coupe, 1.3, in dark grey, 5 speed, slide sunroof, mot and tax till end of august, mileage is 73900, service history book is stamped up until 55000 miles, total 9 stamps, the last service was stamped in 2000 so therefore car has only covered 19000 miles in the last 13 years. It has 4 owners on the book.
Points that you should be aware of are:
(1) There is a dent on driver side front wing. No damage to the paint work. This is likely to push out but you will need to take the wing out to push the dent out (see pictures)
(2) There is small dent on passanger door in the middle (can be seen in pictures)
(3) Small dent on rear panel below the passanger rear tail light (see pictures)
(4) Passanger front seat and rear bench has its stitching come off but you can always stitch it back or put another seats
(5) The center part of the exhaust is blowing from the joint where it meets the catalytic but I do have a spare center box in good condition that does not blow. Rear exhaust (box) is tied with a cable as one of the mount is broken so therefore exhaust system is hanging loose but it wont fall off. Exhaust also has some rattle inside which you can hear it when you go through a speed bump
(6) Battery tray will need a plate welding as its got a hole
(7) car could do with a service (oil / oil filter / fuel filter / spark plugs / air filter) changed due to last stamp being in 2000 and i dont know when it was serviced after 2000
Good Points:
Mot and tax will expire in late august this year so drive it away. Starts and drives very good and pulls well on all gears. Engine gearbox gear change are all good and perform the way they should. Underneath and underside of the car is in very good order. I have treated the underneath with anti rust tetra sealent to prevent it from corrosion or rust. Fuel tank is good no leaks. Heaters inside are good and works on all settings. Seats tilt and slide forward. Engine bay and boot is nice and tidy. All in all nice and cheap little motor that needs a little bodywork TLC here and there as its no minter in any shape size or form. Best to come and have a look and see if its for you or not and we can take it from there. Test drives around the block only (not main road) as car is not insured
Please PM me if you want to view it. I am located in Bedford. I am asking £250 and cant do any lower than that. Cheers
Edited by performancevw
  • Replies 8
  • Views 718
bring you 200 cash
Hi mate
Would that windscreen fit on my polo mk2
Been looking for a coupe s 1.3
To use as a donna car for mine
But don't want spend to much on it (£200 - £300)
Based in telford,very interested as my mk3 golf just given up and need a quick replacment,please mail me straight away so can get more info :) will pay asking price also
sorry dude,doesnt matter guna pass,dont want another sunroof-spit of my old car so wanted it but got sunroof,all the best-
okay no worries
if it hasnt shifted by next friday let me know :)
Where are you mate my scirocco died yesterday
SOLD
