Front seat guides and welding
I've had to replace some of the drivers floor in my coupe, and under the front seat guide (where the lever slots into)
Does anyone know if these need to be seam welded to the floor or will I get away with short runs all the way round for my mot?
The carpet has to be out the car for the mot for my welding to be inspected
Its a bit of a nightmare to weld in places with all the folds etc
  • Views 842
Normally any welding done on cars has to be fully welded. Stupid when you think most cars are spot welded together!
put up a pic it will help
if your replacing like for like you can spot /plug weld it in the same places .....if its a cut n join then seam weld it
Car has passed its mot
Because the seatbelt buckle is attached to the seat its classed as a seatbelt mounting point so has to be seam welded
I seam welded it anyway, not much more difficult haha!
Edited by derskine
