Cupholder install help ASAP
Trying to install the polo 6n2 cupholder having a bit of trouble can someone give me a walk trough?
  • Views 2k
Depends which bit you need help with. You need to undo all of the torx bolts from the right hand side of the dash and take each piece off. There is also one in the glove box on the left hand side. Then when you have the cupholder out, you can use a screwdriver and lever each clip up and pull it out (easier with two people) The new one should just slide in.
Edited by Dialled for life
How many torx bolts is there? Can only see one this wedged in behind the steering wheel that I can't get to... Any ideas?
You need to remove item #3 to get at the two screws at the rear of the cup holder
But to remove that bit of trim you need to first remove the drivers side lower trim
Thanks not arsed removing the trim so I'm going to count on 3 screws, thanks
Really doesn't take that long and there is no other way without breaking it..
If your not arsed why bother asking for help :shock:
Sorry if I came across as rude! Got it all in the end anyway thanks for your help
