Mk2 Clocks
Hi all
So whats the correct way to tak them apart without destroying them :/
Need to change the speedo needle, give the faces a general clean and also put thtrip meter needle in as thi ones snapped.
Another thing is where the speedo pushes into when in the car, its been bent, not a great deal but enough to make it so hard to fit. Any help with that?
Thanks,
Josh
  • Views 766
Just take your time, and be in an atmosphere where you're not being interrupted all the time etc. Dining room table is my choice.
Some of the fittings on the back are brass nuts with tiny threads in the middle (you'll know the ones) obviously these take nothing more than direct fingertip torque when tightening, even though you'll need a tool to undo them.
