Ross Tech Fault Code
Hi,
After scanning my car this fault code has popped up. I cant find any info about it. The code reappears after it has been cleared
Address 08: Auto HVAC
Controller: 6Q0 820 045
Component: Klimaanlage X0840
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
  • Views 4.6k
That only includes:
  • Check DTC Memory
  • Implausible Signal
  • No Communications
Mine says 79-00 - Please Check Fault Codes
Check for fault codes in the instrument cluster
