paint inside sills?
hi guys
the outer sills on my mk2 will soon be coming off but this is my first time doing this kind of work so basically my question is what to i paint the inner sill and inside of the outer sill? just primer? seam seal etc
also what kind of products would you guys recommend? like should i be using etch primer or epoxy on the inside ( and the out side for that matter ). also i noticed theres some kind of stonechip paint/seam sealer on the out side currently, will any old stone chip stuff do or do i need a certain product?
cheers
kyle
hi guys
cheers
kyle
If you're spot/plug welding the sill back on then just done paint within close proximity to the spot weld areas with whatever - not waxoyl though (it goes on fire)
If seam welding it on then you'll need to leave about an inch of bare metal on each edge, paint will just burn away
You can always spray sills with cavity wax/waxoyl once done
Can use a weld-through primer along the seams..
You could do that too.
I've never used it myself, I was always under the impression primers are porous, so never bothered to try it,
but I'm certainly no primer expert so could be wrong
cheers guys thank you:)
i remember seeing a thread (on here i think) where a fella covered the outer sill in brush-able seam sealer what apparently doesn't mind the heat from welding, but I've heard people say this isn't gd as waxoyl may not be able to get where it needs to?
i heard that the weld through primer but i thought the same thing surely it needs to be covered with some thing?
also once the sills bk on whats the best way of getting loads of waxoyl in?
Probably would avoid covering it in seam sealer
You're probably better with dinitrol cavity wax rather than waxoyl, in a few tests it's been proven much better
For getting it into the sill, you can use the seatbelt hole, just don't get any on the threads ;)
Bottom line is any welded repair that you can't easily get to the back of after welding is never going to be perfect
Edit - Actually I forgot that there are removable rubber blanking plugs on the inner sills on polos
Edited by derskine
