Weber TLA carb flange/gasket
have found something similar on GSF but read a post with different part number. does GSF use their own?
found on one VW herritage but is £70!!!
its a 1043cc Breadvan, 1990 with Weber TLA. anyone help with links or recommend a good website.
  • Replies 9
  • Views 659
Please DO NOT use a GSF one.
They are shockingly bad quality, I went through three in six months.
Managed to get a decent Febi item from AVS.
thanks for the heads up. you have weber tla too?
I've got a GSF one on mine that's lasted ages, you must've tightened it too much :-p
is there a specific torque for this or just couple of knuckles on it?
Dont make it too tight and tighten the nuts progressively
Just a little more than "a nip up" will do, if the torque is uneven or too much they tend to tear
Stupid design, nothing wrong with solid carb bases!
Not at all.
The tapped holes for the mounting studs were'nt deep enough.
Second one was just 'nipped up' and the rubber was of such poor quality it peeled back.
Every time I got an apology and replacement due to poor quality.
if they arent deep enough use a washer under the bolt. simples really lol
Not really, the holes are coutersunk so they need to sit below the Weber adapter plate so the carb can sit flush. Ended up trimming the bolts down second time around. After that I managed to find a decent brand that actually fitted properly.
