MK3/MK2F POLO COUPE GENESIS 1.3 BREAKING
Hello
I am breaking mk3/mk2f polo coupe genesis 1993, many parts are available (except complete exhaust system), the car is 1.3 AAV, Just PM me what you after, smaller items can be posted, larger items collection only but can be posted for postage cost but will need to check how much, cheers
Front bumper £15
Rear bumper £15 SOLD
2 x Wing Aerial £10 each posted
Boot lock & door handles both side with one key fitting all locks £10 plus postage
Washer bottle £5
Header tank £5
Heater resistor NOT AVAILABLE
Bonnet £10 (some scratches and lacquer peel)
Tailgate £10 (some tiny spot of rust and blister)
Driver side front wing £15 SOLD
Passanger door £15 (without window mechanism/wing mirror/door handle)
Driver door window mechanism £10
Sunroof spoiler £5
Rear lights £5
Passanger side wing mirror £10
Driver side wing mirror NOT AVAILABLE
headlights pair £20 SOLD
Grill £5 SOLD
Front long panel under grill £25
Radiator £15 (will need new fan switch)
Genesis front seats pair £10 (Driver side height adjustable lever needs attention)
Rear seats £20 SOLD
Fuel pump £15 SOLD
Blue coolant sensor £10 SOLD
Speedometer with rev counter £20 (I have set the mileage to 000000) SOLD
Interior switches £5
Headlight switch £5 SOLD
Heater plastic panel SOLD
Interior carpet in black in mint condition £20
Genesis door cards in dark grey £20 SOLD
Orange front indicators pair £5
Orange side repeaters pair £5
ECU £30
Radiator fan and motor £10
2 x relays located next to ECU £12 posted
Parcel shelf in mint condition with cables £15 SOLD
Starter motor £20
Alternator £20
Gearbox £100 (5 speed)
Throttle body £20
Battery tray £25 NOT AVAILABLE
Heater blower and motor £10
Shock absorbers front and rear complete set £20 NOT AVAILABLE
Boot gas struts £10
Thermostat (new) and housing £10
Steel wheels with tyres £30 (Tyres need changing)
Steering wheel £20 SOLD
Boot carpet £5
Sunroof arms slightly rusty but works fine £5
Here are the pictures of the car:
Edited by performancevw
  • Replies 61
  • Views 2.4k
Hi what would you take posted for the steering wheel and the bit of trim on the rear arches that are hidden by the rear bumper? Thanks
Edited by nige8021
No need to quote with all the pictures
Where are you located? How much for the aerial posted if it still works?
located bedford, aeriel is in good condition with long radio cable but i dont have the black plastic base that aeriel sits on on the wing i can send you pictures if you like, cheers
i can do £35 posted all in, cheers
Hi thanks just to make sure you do know the trim bits I'm on about?
£35 posted is fine thanks
yes the 2 black ones on the rear arch where it meets the rear bumper?
Thats brilliant thanks how do i pay?
Are the rear seats split back and what condition are they in? PM me please. Thanks.
PM'd
How much for the tailgate and back bumper? And what condition are they in?
I mean the tailgate looks fine from the outside, assume there's no rusty bits or dents I can't see?
how much for the front struts?
Pic would be good, I have an aerial already just has a screw in the end. Are they interchangeable?
Tail gate has one tiny rust blister otherwise in good condition no dents but i will double check the condition properly. bumper is in mint condition.
I can do 10 for the struts if you collect or i will need to find the postage if you want posted
does that include the wheel bearings and are they any good? I would need them posting because I'm 2 hours away... Cheers
If you could get a pic of the rust blister and let me know what you want for it, I'm interested in the tailgate and bumper and can collect on Tuesday next week.
not too sure on the wheel bearings to be honest as i have not driven the car at all so cant say if it is in good or bad condition, did you want the whole leg with struts or just the 2 struts
I will get the picture of the aeriel tonight
okay will PM you tonight
Cheers :)
the struts are attached to the hub part... I don't need the shocks, just the leg as you call it. the wheel bearings would be nice as i wont have to have the job of putting new ones in. i am making my own coilovers so i need those bits to start with.
okay i though you need the shocks i have the struts available but i am not sure on postage to be honest probably be expensive due to weight and size plus it will be on the car for next few days while i am moving the car around to take few bits and pieces. You can always arrange your own courier though
I can sort the courier but is it still a tenner for the bits I'm after? postage will be about £10 with a courier
