Replacement sills mk2/3 same?
As title really, can't find replacement sills for a mk3/mk2f coupe but can find replacements for mk2, are the sills the same?
  • Views 2k
That it matters, yeah. Some say the breadvan ones don't line up on coupes - bollocks, i used breadvan ones and they were bang-on as far as they reached.
If you're using the MK2 coupe sill trims you might not have all the holes you need and might have to get an extra drill bit out along with all the other tools sprawled everywhere, as you do when welding such panels on.
If you have a MK2 sill panel there might be a couple too many holes, again this shouldn't be a problem for someone who has several metres of welding wire by his leg.. They're the same as makes no difference.
  • 1 year later...
To bring this thread back from the dead, can mk2 polo saloon sills be fitted to a mk2f bready??? My sills are dead and rear jacking point by filler neck is a goner
