Front seat wobble? 6N2
Hi guys I have a 2000 polo 1.4 6n2 which i have ripped the whole interior out and replaced with a GTI one trouble is the front seats are in all well and good but were the front is bolted in by that one nut theres abit of play in the seats i was gonna just stick sum washers or some kind of spacer in there to stop them moving but is there a reason that any one knows why its happining?
8-)
  • Views 1.5k
At the front of the seat where you slide the rail in and then put the nut on there should be a rubber thing that sits between the rail and the metal if that's not there then the seat will wobble at the front :) hope this helps
And at the back of the runners ther should be a plastic/nylon bit slid on, if this is missin it will allow movement in the rail, alway worth ripping one back out an comparing to your old seat to see if it's there or not
Yup cheers is the rubber things at the front that were missing also noticed with the door cards there should be a white security strip on top I took the door cards off busted nesrly everyclip and found there not to be a security strip obv to hold the top of the door card down nicely can u get hold of these and are they bonded on or just slip on the door
If I remember right the clips are able to just pop out so you should be able to replace them not sure if you can buy them from vw but I'd say you can
eBay
