Early Wiring 1.3SPI ECU
Hey guys, I'm in desperate need of an ECU from a 1.3SPI but with the early wiring, so the bigger ECU. I've popped a 1.3 into my breadvan and the ECU doesnt match the plug so I'm stuffed until I get it!
  • Views 209
I had the same problem when I converted my breadvan, so I've got three different ECU's..........
Chances are I have the one you need, you just need to confirm which you want.
PM me if you still need one.
