Hydro or air?
so basically i just want to know the advantages and disadvantages of hydraulics and air ride and to compare the two:
cost difference
problems that can occur
fitting difficulty etc
any information will help :)
cheers
  • Replies 17
  • Views 5.4k
Coilovers a lot less problems and a lot cheaper :)
i'm already on coilovers haha
i want to upgrade to either hydraulics or air ride but am undecided between the two!
If air leaks its just air
If hydro leaks its oil everywhere
On the plus side if hydro leaks you know where the leak is easily traceable
Whereas if you get an air leak it can be a right bitch to find and solve
okay well that makes sense
any idea on whats more reliable?
Neither is more reliable they both consists of the same components. I personally would go air as its much cleaner to install and to work with however the bags them selves are a weak component. We're as hydro it's just a shock.
I would still stick with static though to many people going air nowadays I would rather look good everywhere rather than just parked up
okay thanks :)
Only been in one car with hydros it was a toyota mini truck, completely sweetride with a pretty decent sus set up. Only problem is with Hydros you need a fair amount of batterys to power it (the bed of the truck had about 4 leisure batterys). Air is more compact and does effectively the same job although you loose roll stiffness , coils are more for handling characteristics.
yeah because I'm getting quite annoyed with feeling every single bump in the road!
so air would be a more comfortable ride?
You can tune air springs just like a coil spring, probably feel to roll more as people drive around with them at a higher height to fixed height suspension.
Air leaks shouldn't really occur if it's installed properly, leak detection spray makes it very easy to find leaks too.
Comments regarding packaging sound about right, air is generally a smaller setup, but you can't really bounce a car on air unlike hydro.
What do you want to achieve?
i guess the main goal is to sit it on the floor ahaha
i will be getting a daily so the polo being off the road wont affect me, just want to bring the standard of it up.
i think i'm leaning closer to air ride and could probably get a deal with the kit and fitting
What else though?
Do you just want to drop front and rear, individual corners, good ride quality? Good handling?
Slow/fast to raise up etc?
Its all about what you want to achieve. Hydro's are for pimps, air is for fags (sorry kiz :lol: )
Hydro's don't need loads of batteries, mine just had one and was fine but the more power you wanna put through it the more batteries you will want (more power you have the quicker it works). The hoses are a lot bigger and more industrial tho and if they do leak it does get very messy (hydraulic oil bukaka :lol: )
If you want a set up that is all nice and tidy and just goes up and down then air ride is your thing, if you want something more hardcord that could literally bend the cars shell if you pushed it hard enough, then Hydro's are the way to go
Hydro's make some fucking cool noises too :wink:
Trying to find some video's of mine but it looks like photobucket has eaten them :-/
Edited by Mclovin
i want reasonable handling and ride comfort
time it takes to raise/lower doesnt bother me
want to be able to control each corner individually
the main advantage of hyrdo in my opinion is making the car bounce, which is a very good party trick but like you say can end up damaging shit.
i'm quite chill about the whole thing so air is probably looking a bit brighter to me
Air probably is the way to go for you but get a kit with decent management as it will not only give you better control over your system but also allow you to tune the ride of the car a lot better than a basic setup
You wouldn't cause any damage with Hydro's unless you wanted too, making it bounce without preping the shell to take it would be the easiest way to achieve this
Thanks for the help :)
I'm probably going to settle with an air ride kit.
Any preferences on brands anyone? :)
screw you!
at least mine didnt make an oil leak similar to piper alpha
