My eventful trip home..
Getting towed....
Today's progress before rain -
Took my near-side drive shaft, hub, brakes out as my driveshaft came out of the gearbox. but because my hub nut is seized couldnt get just the driveshaft out D:
(ignore the red cable holding the clutch cable out the way)
  • Views 593
I had a similar thing on my vitesse i was driving them crunch bang. Where my driveshaft goes into the box it blew a hole. I hope its nothing to serious mate good luck
The box seems fine but ill find out when i put a new shaft in D:
You are so lucky it didn't take out the box!when my driveshaft came undone it smashed a tennis ball sized hole in the back of the box and a recon unit wasn't cheap!
all fixed now, luckily the box and mounting is fine :)
