6n2 door cards on a 6n help
Bought a polo with half a 6n2 interior already put in. Seat, rear cards and all the plastic bit in between. Now my question is how do I put rhe front door card on had a quick look my self and realised the speaker pods were different so I go some from a gti but to no avail. What am I missing. P.s I have all the relivent door handles amd clip just can't get them to fit any help would b greatful
many thanks pedge
  • Replies 9
  • Views 1.2k
Anybody put 6n2 door cards on a 6n at all cant be a new thing surely!
Should fit, considerations would be electric window switches and whether they clear the 6n dash or not
you need to drill out the bracket that holds the mirror cover on, then you need to relocate the speaker mounts too, you also need a set of 6n2 rear pull handles as these are flat and fit flush with the door, you might also need to put a bend in the rod that the handle pulls to open the door. I think thats everything i did, never got round to wiring.
hope this helps abit
Thanks alex i'll have ago with you are advice cheers
Only problems I've seen on mine are the plastics behind the mirror as already said, and I just screwed my 6n speakers into the doorcard
I did this today, firstly you will need to cut a small bit of the foam cladding away because the new door pulls sit in a different location to standard 6n ones, and you also need to bend/shorten the pull wire so that the handle releases the lock fully, or else it will flap but not actually open the mechanism.
speakers will need to be remounted as previously said.
you can either use dummy switches or rewire the electric windows
I'm in the process of doing a 6n2 retrofit into a 6n, so will post a guide when finished, it is mostly a straight swap with minor modification.
I hope you manage :-D
It's going well mate, will need to pop round and get a couple more bits off your 6n2, so will do that when I get the rear seats :)
Yeah if u post some pics up of what needs doin i'll have a go. It would help me out loads thanks
Pedge
