Polo Openair 1.4 CL 3dr Silver
I brought the car in 2010 with 65000 miles on the clock for a lady owner, I am the third owner from new. However it wasn’t driven very much 5 miles every other day. The breather was all blocked and the tappets where noisy. I fixed the problems and the car has served me very well but it’s time to move on I’m in need of some funds to purchase a 5 door car.
Very good on MPG and has been unmolested. I have serviced the car with good quality parts and oil.
Make: VW
Model: POLO OPENAIR 1.4 CL 8V 3dr
Year/Reg: 1999 T
Mileage: 85500 will go up slightly
MOT: April 2014
Tax: 10/2013
Good points:
8 new tappets fitted at 65000 miles,
New Oil separator (Oil Breather),
Sump cleaned and resealed,
Oil pick up cleaned,
Head gasket, valve stems oil seal, valves ground removed carbon build up and timing belt done at 75000. Due to valve stem oil seals being dry and crack,
Rear brake pipes change for MOT 2012 (copper and rubber)
New Windscreen fitted last year, MOT 2012 sush a difference with no scratches.
New Sachs Clutch fitted (27/07/13) See picture
New Fly wheel, fitted (27/07/13)
New Bearing Sleeve (2707/13)
New Starter bush (27/07/13)
New back box fitted last year,
New thermostat housing and thermostat 2012
New Temp sensor 2012
Rear arches are in good condition i treated it with krust to help stave off the dreaded rust.
MOT:
19/04/2013 83779
24/04/2012 79540
29/04/2011 65512 I owned the car from this MOT
31/03/2010 60296
Bad points:
Bad points:
Small rust blister on drivers door skin. See picture
Small dent in bonnet,
Slight rust under fog lights,
Few car park scratches and stone chips,
The starter motor is a little noisy, was thought to be a damage fly wheel on inspection starter bush inside gearbox had broken, was removed and new bush fitted. Starter slightly noisy because of the bush being broken, car starts fine, read worse than it sounds.
Rear bumper has markers from previous owner unloading push chairs from boot,
Dent in rear valance near exhaust (from previous owner)
Trim under front light has broken clip on passenger side,
Front fogs light fitted by previous owner but never wired in.
Passenger door spline broken but on order and will be fixed before sale.
Pictures:
Price: £785 ono
I can take any photo you want and answer all question.
Contact details: Club polo Email or text 07595703255
Edited by residentmelon
  • Replies 9
BUMP!
TTT!!!
Hi mate, all the replacement parts you fitted, did they NEED to be replaced? or was it just to be on the safe side?
The MOT stuff like brake pipes etc where (advisors) and because it was the missis car I to made sure she was safe.
Tappets and breather stuff was easier to buy new and replace.
I put a clutch in it as I had a spare brand new one and make it easier to sell.
And while the gearbox was off replaced the other items to be on the safe side. and while it out you might as well nothing worst that having to take it off again to replace little parts.
Went for a drive in it this morning and I must say what a difference a quality clutch makes.
The one we took out did have made in spain on it.
Whats the lowest youd take for this pal?
£750
Open to Offers
Just tried to pm you mate with no luck :( Says you cant recieve any new messages.
Can you pm me??
  • 1 year later...
MODS please delete new topic started with new price
thank you
