polo went crazy
Hi folks got a 2000 polo estate with a 1.416v APE engine in it and went to change the power steering pump, now when doing this the battery was not disconected and the alternator was taken off, during this process wth the keys out of the igntion all of the dashboard lights started flahing and buzzing, and is doing this every time time the igntion is switched off and key taken out. any help would be great
  • Views 597
clear any fault codes would be my first port of call
Done that :-( still same
Did you short the live out from the earth to the chassis and have you connected everything back up properly.
As far as i know it was connected up properly, how can i tell if the earth has been shorted out?
