I feel such a pillock
Hi guys i bought some more bits for my polo today and 1 of them was a set of clocks with the rev counter.
I happily set off and got the old clocks out then swapped the speedo over which would show my speed.
I put it all back together and was happy. I then tried to change my steering wheel over but i didnt have a socket big enough(me thinks its a 24mm)
So i put the horn wires back on and put the cover back on.
I then started the car and there was this metallic rattling noise i thought this is odd it was fine before.
I then pull away indicate then turn the steering wheel to the right and the horn goes off. Oh no i thought so i took the cover off and then i found the cause of all this trouble...
Id left a socket in the centre of the steering wheel. :retard: :retard:
What made this worse is i have only just done this at 9:30pm today so people wernt best pleased but I'm happy i now have a rev counter
  • Replies 31
  • Views 2k
I always loose tools in the engine bay, usually end up going through the windscreen of the car behind me on the bypass whilst i'm giving it a test run.
Tailgaters deserve it.
Often get a few bolts left over, too. Went out once and the rear struts weren't bolted to the turrets - another time i got to the bottom of the road and the brake pedal went straight to the floor.
It's easy to forget things, we all do it.
Blimey MikeyMK that makes me feel less an idiot now at least I'm not the only 1
Spanners left in the tool holder bit where the mk2f bonnet catch is.
Random clunks where your not sure if spanner or something important. :lol:
Largest thing I lost when travelling.......driveshaft weight.
i went to mcdonalds and i went inside my mate in a different car got into the boot and satyed in there till we got going down the bypass and i heard a roar in the back i was like what the hell my mate tryna keep a straight face by me in the end i craped my self and pulled over and got out all i kept hearing was a slight roar lol idiots lol
You're all making me feel better thanks :badgrin:
Haha I would have just dropped him off somewhere remote and made them walk back
hehe dont worry i took the ht lead off his car a couple of weeks later lol :) was a laugh seeing him driving sounding like a tractor :)
I forgot to tighten one of my wheels as I found a a few weeks ago when it started rattling/banging like a bitch
where abouts in shropshire you from dude?
around whitchurch bud why ?
leaving your locking nut tool on the bolt and driving off is always the one!!
:nod:
Did something on my old jetta once couldn't find one of the allen keys so just chalked it up as lost. After about 6 months of driving it around I had it jacked up doing something under the front of the bay and found the allen key just sitting precariously on the wishbone, fuck knows how it managed to stay there for all that time, most of been partly due to all the oil/grease covering everything :lol:
always loosing shit tho, and don't think I've ever done a big job and not had nust/bolts/washers/unfamiliar looking bits of car left over at the end
Pretty sure he's from Whitechurch way too
Doing brakes on the likes of BMWs which have the silly little spring clip thing, always forget to put those back on until the car is back together and all the tools are put away.
Countless times I've forgotten to nip wheel bolts up, luckily never lost a wheel though, closest I can was my Audi A3, after fitting new pads took it out for a drive, ended up being quite a long test drive, came off a roundabout and suddenly got a massive knocking. Pulled over to find 3 of the wheel bolts had escaped and the last 2 were only finger tight.
I've been driving around with my old thermostat behind the front light for the past few days, only noticed I'd left it there today lol
Drove home with a multimeter and a box spanner in my engine bay too on friday
Potentially two of the most ridiculous things to leave under there
Edited by derskine
I was doing my front brakes years ago n done the disk n pads n had taken slider bolts out to grease them up. But when I popped drivers side ones back in I forgot to tighten them up with the Allen key. Was few days later n a was driving down a hill quite slow was lightly braking. Heard a little clunk n seen something flying up off the road behind me in my rear view mirror. Thought wow that was a big stone. When I was on my way back I seen something on the road n just had a gut feeling it wasn't that stone that I thought I seen earlier. So stopped n it was half a chewed up slider bolt lol. I thought oh noooooo. Got home checked the caliper. Both slider bolts were gone lol. Luckily no damage caused. Would have been a diffirent story if them bolts had gone thru the windscreen of a car behind me. We all do dumb things eh!
This is the best thread I've ever read on clubpolo lol but ye it's very easily done :) deffo the worst one is leaving the lock nut socket on the wheel and driving off. Has happened plenty of times id say, luckily never to me though haha
o ye another 1 i left spanner and few screwdrivers bits on my winder wiper and its started raining you guessed it kinda threw them off when i put the wipers on lol,.
I've managed to forget twice now to do the wheel bolts up fully... that's a pretty scary feeling
forgot to tighten cam cover the other night, oil everywhere hahah
Also manage to forget to do up the two bolts on the timing plate thing for the timing mark on the crankshaft... drove for about half an hour then there was a loud clank and a sort of tung tung tung tung noise... opened the bonnet and the cambelt cover was jumping about all over the place, turns out there was a bolt through the belt.. lucky it didn't split, did some damage to the pulleys though
i live in drayton and kick about in whitchurch :lol:
I did one today.
My skoda had been a bit low on oil for a while, and me being me, I'd not botherred to top it up. Earlier on, it started tapping loud, so I vowed to buy some oil after I'd done what I was doing.
On my way to buy the oil, it startted misfiring, badly. Which if you've been running low on oil, on a hot day, listenning to your engine tapping, pretty much makes you think you've fucked it.
I parked up, walked a mile round trip to buy some oil, chucked it in, and tried again, still misfiring. Waited for it to cool off (took ages), tried again, still tapping and misfiring.
Called the RAC thinking, yep, that's it, I'm getting recovered home with a dead van for the second time this year.
Bloke came out, cleaned the spark plugs and it's been fine since.... god I felt a idiot! :paranoid:
Brilliant Yeti but at least it was nothing serious and its still working
