Need help with seats! Polo 6N2
Need a detailed explanation of front and rear seat removal of a 6n2 and then putting seat cupra r seats in to replace them!!
Rob
  • Views 1.7k
Removal of fronts seats:
Slide seats forward, 2 plastic trims in runners pop off on both seats. Slide back, one Allen key bolt with but on end undo that lift the slider handle and slide the seat backwards and it will come out.
Rear: lift base up and pull metal arms out of holes.
Backs pull the tabs up and drop seats forward, you will see where the seat goes in by the the outer sides, clip pushes down so you can pop it out. On the inner side of the seat are 2 "U clips" pop them up and the seats will lift out.
Not sure on supra seats but I think the bases need welding to your polo ones or they won't fit
As he said. It really is easy, I think he means the ibiza half leathers?
Yeah, Cupra R seats = big job
Ibiza Cupra = fronts straight in & some clips to change over on the back, there's a guide around these parts somewhere.
