5x130 to 4x100 20mm adapters - SOLD
as title says, porsche rims (5x130) to VW (4x100) hub adapters for sale. Zinc passivated steel so won't rust and the threads won't strip out easily like they can on the ally ones. Come with the bolts to mount adapters to your hub, and a 'key' to tighten/loosen them.
you will need your own wheel bolts. Each adapter is 20mm thick.
set of four, located in newcastle upon tyne.
£110 delivered to mainland UK.
978775B1-D0B0-4533-895C-3CCA45085E03-204
8FAC2700-697A-411F-A47B-4F5A21DFBCB8-204
Edited by macksimus
  • Replies 9
  • Views 236
bumperino
up she goes
Take 80 quid? Are the threads m12?
let me check on the threads tomorrow
£80 is too low but i can meet you half way at £95
cheers
mack
Edited by matt01
Hi, If the bolts that attach them to the hubs screw in the threads tight then they will be,
90 quid posted? How does that sound?
I just want some steel ones cause my h&r set are ally :(
sorry man - £95 is as low as i want to go. Gonna stick them on edition if you don't want them for that.
cheers
mack
Right I'll have them, provided you've checked the thread, pm me.
yep - just checked this aft. M12. i'll pm you the deets
cheers
mack
sold to max. cheers dude
