Vibe SLICK PACK 2.1
Parcel self install that came out of my 6n2
Very good condition
Few marks here and there
Reason for sale is my car was written off and no longer need it
Bought from new RRP:199
Asking £99
Collection only
Tewkesbury Gloucestershire
Vibe SLICK Pack 2.1 A full installation in a box compromising of SLICK A1 amplifier SLICK SLR enclosure SLICK 6c9s and all the cables necessary.
A full installation in a box compromising of SLICK A1 amplifier SLICK SLR enclosure SLICK 6c9s and all the cables necessary. The Slick 2.1 Pack is perfect if you are looking for a quick and easy way to greatly improve your car audio installation.
Vibe SLICK Pack 2.1 Specifications :
Height 360mm
Width 400mm
Depth 400mm
Driver SLICK 12"
RMS Power 400w
Peak Power 1200w
Minimum Input 200 w RMS
Turbo Ports n/a
Characteristics Deep Smooth Bass
Recommended Amplifier SLICK a2/a3/a4/a7
SPECS SLICK A1 Amp
Type 2 channel
Height 65mm
Width 380mm
Depth 245mm
RMS @ 4 Ohm Stereo 2 x 100
RMS @ 2 Ohm Stereo 2 x 160
RMS @ 4 Ohm Mono 1 x 325
Max Power watts 650 watts
Freq Response 20 Hz - 20 Khz
SNR 93 dB
Crossover type LP / HP / Flat
Crossover range 45 - 300 Hz
SPECS SLICK 693
Type tri-axial
Configuration 3-way
Speaker Size 6" x 9"
RMS Power 160 w
Minimum Input 60 w RMS
Peak Power 480 w
Sensitivity 90 db
Freq. Response 55 - 25 khz
Mounting Depth 75mm
Mounting Diameter 220 x 150 mm
Voice coil diameter 35mm
Magnet material Ferrite
Magnet weight 20 Oz
Magnet size 100 x 18mm
Magnet rating Y30
  • Views 388
how much just for the sub? pm me
£90 if anyone is interested.
Edited by poke360
