Torque sump plug?
Do any of you guys use a torque wrench on your oil pan bolt?
  • Views 9.3k
No... Just FT
for reference, FT is not finger tight :lol:
Don't FT probably strip it:
Correct term is tighter than loose, looser than stripped
oil drain plug standard torque for M14
10 FT-LB into aluminium
15 FT-LB into cast iron
my wrench starts at 25Nm
Thought FT tight might be NSFW.
Edited by dvderlm
It doesn't need to be particularly tight, a reasonable pull with a 19mm spanner will squash the soft copper washer enough to ensure a good seal.
Yeah but a reasonable pull to jamie would b like tony doing it as tight as possible
What i tend to do now is use 2 fingers to finish it up at the end of the spanner.
You can always tighten it up more.
