Tyre sizes help.
I bought some lenso bsx for my polo 6n2 gti I have put them on but the tyres are scrubbing tyre size is 205-50-16. Now I want stretch a good look not so serious it's dangerous so should I go for 195-40-16 or 185-40-16 what do you think ?
  • Replies 30
  • Views 1.5k
I bought some lenso bsx for it tho and there 7.5j what size would look good 165 you think ?
ah shit sorry i'm half asleep at work. have a look about on tyre stretch and get the size you think looks good!
build the car how you want dude, not how someone else wants you to build it!
Cheers bud I love the 165 but will it be reasonably safe ?
you'll get loads of people saying that they're not safe (some po-po included) and the stretch is a bit extreme... your main problem will be getting them sealed so they hold pressure.
Okk what's the next best size then because 175-50-16 would scrub wudnt it.
if you're running 205/50s now, 175s shouldnt rub.... depending on offsets of course.
It's because of the profile 50 but 175-50 shudnt scrub should they because they will stretch ? It says et30-35 then on other side et 20-25 lol
the width of the tyre will mean it'll stretch with a 50 profile on a 7.5j.
wtf? they've sent you 2 different offsets? are they not meant to be so you stagger them front and back?
Noo it says that ok the back of every wheel lol :/ will it be better just getting 195-40-16
bloody replicas... :lol:
do what you think will work mate! i dont know how they sit atm in terms of poke and stuff... chuck a couple of photos up.
buggar lol I've just swapped them around lol well basically the tyre it to large its been rubbing on the inside of plastic arch then it sounds like it catches the wing or summat when I'm turning :(
So the tyres on it atm are 205-50-16 and profile (50) is too big so if I put 175-50-16 will it still scrub because it would stretch wouldn't it runs are 7.5j
they're probably rubbing because the rolling radius of the wheel is too big. I'm guessing for a 16 inch rim on a polo, the profile should be 40. If you put a 185/50/16 or maybe even 175 on it should give you a nice amount of stretch with no rubbing, thereby reducing your rolling radius, and giving you a more accurate reading on your speedo.
Thank you goood answer so you reckon the 175-50-16 won't scrub but what if I lowered it is that the best tyre option
so its rubbing at standard height? whats it rubbing on? arch or strut?
Inner plastic arch and it sounds like wing when turning
Pic
Pic 2
jeeeesus they're huge haha.
175s!
I run 165/50 on a 7.5 and have had no issues they took a while to seal but know are perfect and look great aswell
165 jesus...skinny!
For reference a 182 Clio takes a 205/45R16 on a 7J rim so they are already a lot smaller than what you have. There's 0 stretch on them.
A 195/45 or 185 something should be suitable. I wouldn't go less than a 185.
I personally have no choice as I wanted my car low and wide. Hence a the strecth needed to get it under the arch. If I run a 225 like what is recommended I would neved pull of the wheel. It all a choice of if you wanna Look good or drive fast
What about 175-50-16 tho would they be ok no scrub and good stretch.
