Tyre sizes help.
To be honest a 195 45 will sort your probably hardly any visible stretch you could get 195/40 nice low profile
  • Replies 30
  • Views 1.5k
But 175-50-16 give me good stretch won't it and they won't scrub ?
I run 195/40/16 on a 7.5 here is a picture so you can see what it looks like -
To compare this is a 165/50 on 7.5. I know there 15 but same tyres
It's up to you what tyre you go for your the one driving It. Obviously the smaller the tyre the less grip.
Them 165 look good ;) will it be same for normal driving
I've had them on for 6 months and covered a fair few miles and a few have been spirited drives and it grips fine in the dry. But as mine is cambered all round in the wet it gets a bit tricky. If you don't mind slowing down a bit for corners then you will have no problems and keep on top of tyre pressure or fill with nitrogen
