how do i remove the gearbox of a hz engine?
how? I'm breaking mine and keeping gearbox so i need help to take gearbox out
  • Views 718
Big hammer.
Lol, beasically just undo anything you see.so driveshafts gear linkage, lower mount clutch cable etc, then it has I think four bolts to hold it to the engine. And abviously the upper mount.
You could also jack the car up high then release everything and drop the engine out then split it later. It's probably easier this way if your not putting it back in.
