mk1/2 mechy engine dizzy with accuspark kit
Hello guys need some dolla and i have these laying about!
They are mechanical headed engine distributors that have been converted to run an accuspark electronic ignition kit instead of points.
All you have to do is replace the resistor wire to your coil with a normal 12v wire and its plug and play.
Means you never have to set your points gap again! :)
After £20 each. Collection from luton or west london.
Could potentially post.
Cheers!
  • Replies 9
  • Views 303
how much, potentially, would P+P be ?
Dunno mate, probs around a fiver, I'm busy at work till next friday though so thats the earliest i could post
Edited by erixtar1992
I'll have one posted. No hurry.
i'll take the other then please, again no hurry,
they could both be posted to the same address
if Steve is ok with that to save £ ? NG14 6PE.
PM Paypal ID and i'll send the cash asap.
Sounds a plan. :)
I've just had winston message me because one of them was originally his, and hes unsure if it actually works. Ill send both and you can try both out to see if they work or something??
still have these
Did you manage to check if they both work?
i have no way of testing them mate
