Two white mk3 coupes for the breaking
Have you got any mirrors?
  • Replies 53
  • Views 2.6k
No the J reg didn't have any and the L reg's have had the wires cut for some reason.
Alright then no problem
Hi mate, whats the condition of the front scuttle area on drivers side and the sill back section on drivers side and would you be willing to chop them out if any good? What are both rear arch spats (front of rear wheel) like?. Also need a couple of the rubber sill bungs as lost a few somehow.
Still got these, most of the body panels are spoken for. Got the good tailgate, two drivers front wings and that's about it!
Plenty of clear glass, coupe quaters etc.
Still got rear lights, carpets, parcel shelves, lots of bits of trim
More updates to come including suspension and wheels
Edited by Gaz
I need a rear beam. Can you help?
GT I presume? These both have standard ones
Edited by Gaz
nope, just a standard one... for an 89 saloon
How much for the chrome door handles posted man?
Will find out what postage is, will start by saying £10 + post, maybe £13 all in?
Hi, do you still have plastic timing belt cover, the one that sits behind the cam pulley?
dont suppose you have any engine parts available
I have a 1.0 that i have dropped a 1.3 spi in
I'm interested in making a 6n GT
so do you happen to have
a GT MPI inlet
Fuel rail and injectors
ECU
GT fuel pump
GT Cam
I don't think I have any of these spare as I've had two engines come in where someone has cut the back off instead of removing the cam sprocket which is a no-no in my book (they could've cut it lower down and retained it)
a GT MPI inlet
ECU
GT fuel pump
GT Cam
No engine parts.
After rear lights?! Also seat belt buckles? And reg lights?
Update with Items sold ( I would update the first post, but I would have to delete some pics as I've posted too many for the forum software to be happy about)
All doors, both bonnets
Both pass. front wings (ergo, both drivers sides still here)
both windscreens (well, one still here but cracked)
rear lights gone
black parcel shelf, (grey still here)
Boot side carpets
g40 door cards
So not much left really now!
Cheers Gaz, Got back home safe (motorway 25 miles longer). Only had to get out the car once to stop the door rubbing on the rear screen 8P
No worries mate
dont suppose you still have a nicer than poverty steering wheel ?
Nope sorry I've already sold both steering wheels.
The cars both got scrapped today but some smaller parts are still available. Will update in due course
Do u still have the brake carrier available - if so are they vw1 or vw11?
Akis
One of the cars was vw1 and the other car had a vauxhall 256mm conversion on it.
Front quarter window seals available?
I've at least one set of bonded mk3 window quarterglass, and probably some seals for normal glass
I'm imagining the Vauxhall brake setup is otherwise spoken for? I know you said no mechanical parts, just thought its worth checking!
Yep long gone
