Coding an airbag module
Hi all,
Having replaced all faulty parts I now just need to clear the final code to get rid of the airbag light.
01224 - Control Module does not match vehicle
I have run VCDS on it and it has shown me that the coding on the module is '12621' but this must be incorrect as the error is still there. There is no suggested coding coming up or anything so I was wondering how I know what code needs to go into this or what else can I do to sort this problem out?
My car is a 2003 Polo 3 door.
  • Views 4.6k
The autoscan returned this is anyone can help
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ3Y218050 Mileage: 114420km/71097miles
Address 01: Engine Labels: Redir Fail!
Part No: 03D 906 032 C
Component: 1,2l/2V SIMOS3 00HS2501
Coding: 00031
Shop #: WSC 00788
VCID: 1E37DA4BB027
WVWZZZ9NZ3Y218050 VWZ7Z0C6722732
3 Faults Found:
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-10 - - - Intermittent
16556 - Fuel Trim; Bank 1: System Too Rich
P0172 - 35-10 - - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 - -
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS2.lbl
Part No: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788 785 00200
VCID: 4687522B4837
No fault code found.
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25742
Shop #: WSC 00788
VCID: 3B7133DF03F5
5 Faults Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
28-10 - Short to Plus - Intermittent
00975 - Heated Rear Window (Z1)
01321 - Control Module for Airbags (J234)
49-10 - No Communications - Intermittent
00906 - Horn (H1)
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 1M AIRBAG VW51 00XX
Coding: 12621
Shop #: WSC 00000
VCID: 2C530083F69B
1 Fault Found:
01224 - Control Module Does Not Match Vehicle
35-00 - -
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 900 H
Component: KOMBI+WEGFAHRSP VDO V15
Coding: 00431
Shop #: WSC 00000
VCID: 33611BFF2BA5
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 10 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 00788
VCID: F0EB54F39A33
1 Fault Found:
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 Q
Component: LenkhilfeTRW V250
Coding: 10140
Shop #: WSC 00788
VCID: 3D753DC71DE1
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 G
Component: 41 Komfortgerát 0002
Coding: 00017
Shop #: WSC 00788
VCID: 3F8947CF17ED
Address 56: Radio Labels: 1J0-035-15x-56.lbl
Part No: 6X0 035 152 B
Component: Radio BNO 0006
Coding: 00001
Shop #: WSC 00788
VCID: 306B14F3DAB3
End ---------------------------------------------------------------------
Just bumping this to say IT'S SOLVED! THE LIGHT HAS GONE :-D :-D :-D :-D
I put a different module in, and turned the car on and the light didn't come on. I am so happy right now.
Would like to thank Nige for all the help in a previous thread.
