Electric window not working
for the last few days the passenger side window was not responding like ti should. uusaly you would pres the switch half way to active and it would stop on release. or press all way to continue too end. the drivers side is working fine, the passenger wasnt, you had to press the switch all the way to mvoe it. i thought the switch was bad, but then i found it would respond the same whether using the passenger side switch or the drivers side switch(for passenger window)
today it has stopped working. the windows cannot be opened from neither driver or passegner switch. all i hear is a clikc when i press either of the switchs. so I'm ruling out the switchs for now. what are the chances of a busted motor and are there any easy ways to diagnose whether i need new motor or regulator or both. any common faults with these and simple things. fuses are all fine btw.
  • Views 657
Let me guess, it's a 6n2? search 6n2 faulty window and loads will come up but the most basic problem is the wires that go through to the door break and an extra length has to be soldered in.
6n2's are notorious for the windows breaking my passenger one sometimes doesn't work then the next day it will
