Central Locking Problem :(
Hi, i own a vw polo 6n 3 door and it came with central locking. The problem is that my central locking locks the driver and passenger door but does not unlock the passenger door. I believe the central locking is suppos to control the boot lock also but my boot only works off the key.
Also in my passenger door the barrel has come out, anyone know a way to fix this?
  • Views 2k
I striped down my central locking pomp. Cleaned it and it is wasting time. Ii is common fault m8. You need to buy new one.
The boot is an unusual one, if you leave the key slot vertical it only works off the key, you need to leave it horizontal to work on the central locking. At least on the estate 6KV anyway
Thoward your right mate, the lock on the tailgate has to be in the unlock position to open off central locking !
  • 5 weeks later...
Pump does need replacing, but i would take the door card off the passenger side and take a look.
Never know, maybe the bar has bent or something !
