need paint advice on my mk2 coupe!
Okay soo unfortunatly seen has my polo has taking longer than thought and circumstances have changed i need to spray my car! I took the plunge to do the bodywork over my half decent paint, theres was a lot of bodywork done in big areas, so i was going to get the car resprayed, but i now have to get the car on the road to get to work as I'm moving.
I need to get it through the MOT at some point.in the next two weeks which will set me back a bit in parts and things,
So long story short i cant afford my respray but i dont want tge polo looking like a shed! Because its only the paintwork letting it down, i need a quick paint option which i can do myself, i dont want to do it matt black or satin etc and roller method
I'm not a proffesional sprayer but I'm not incapable and have patience anybody got any ideas? With a budget of around £50? I know at that money I'm not going to get any descent results but i need to know my options lol
Cheers!
  • Replies 13
  • Views 1.2k
This cost me £14 from poundland
http://www.meguiarsonline.com/forums/showt...-paint-job-quot
that's probably your only chance of not getting a wank looking paint job for under £50 tbh
Pretty sure it costs more than £50 to paint a car with rustoleum
I've spoken to a few guys who've done it, one member of the cortina club sent me a very detailed guide with supplies costing around £250 (using special oil to thin the paint, its too thick to apply staight on)
Edited by derskine
Well i have my hvlp gun in the garage for when i plastidip, and maybe rustoleum could be sprayed on with that? Thin it 50/50 and do it a matte beige or a desert sand? or similair? Matte is easy enough to get good results with. Any thoughts?
£250, was he using gold plated rollers? :lol:
Not sure what special oil your on about but all the guides I've read have used normal thinners to water it down. You will also need to buy wet and dry and what not to prep it but that would need to be bought no matter what method you used to paint it.
Rust oleum, 2.5ltr (will be at least 5ltrs once thined) £42 delivered http://www.ebay.co.uk/itm/Rust-oleum-Combi...=item2a27ef765d
Thinners, 5 ltr £13 delivered http://www.ebay.co.uk/itm/STANDARD-CELLULO...=item4d0dfa0392
6 foam rollers £4.64 delivered http://www.ebay.co.uk/itm/MINI-FOAM-ROLLER...=item336cf58e19
thats less than £60 including postage and all I did was a quick ebay search, no doubt some of that could be found cheaper elsewhere or even just spending more than a minute looking for each thing on ebay. To put it into some kind of perspective it cost me £80 in rattle cans to paint a mk3 matt black and it still wasn't enough for a good even coverage
Thats more like it! Sounds about right to me :) I've never had a go at rolling because i dont have a lot of patience and hate prep work! Haha, i usually plastidip her but unfortunatly thats £96 per gallon without thinners but to be honest if i can skrimp a bit this month i might be able to grab some more!! :)
Thanks for the help peeps! May come in useful in the next couple of weeks!
If i go ahead with the rustoleum i'll be sure to make a thread!!!
should be able to do rustoleum for near to £50...its good stuff I've used alot of it
but dont expect to be done in a few hours ...its lots and lots of work , although i spose you could roller on enough to get it covered and then sand and keep going at a later date when its more suitable
From the link i posted above using white spirits, which is nothing more than slightly more refined thinners and shouldn't make any difference to the finish between the two. looks fairly shinny to me? :?
But either way the stuff you posted is only £5 more delivered than the thinners so still only just over £60. I'm not questioning that he may of spent £250 but I see no reason why it couldn't be done for £50 or at least very close to
Edited by Mclovin
You need 50/50 mix, that is a 500ml tin of it
He used 5L of paint for the cortina
I have seen a few without using the thinners on whole cars and it looks alot flatter than this
Though the bonnet does look good
Edited by derskine
shines fine with thinners or white spirit...considering a big part of it is flatting and polishing it doesnt make much odds
I see no reason to spend that sort of cash on the oil stuff when results like the above can be had using thinners/white spirits
Hmm, fair enough, the way he described it to me highlighted the use of the owatrol oil to give it a shine.
I was going to give it a shot but put off by the cost, if it can be done with regular thinners and look that good I might take a shot at it sometime
